Aftermarket seats post them up
Registered User
There's been various topics on seats but I've seen few pictures.
If you have aftermarket seats, post them up so we can see what it looks like installed.
Also, please describe if the mounts needed to be modified or whether they were a direct fit.
Thanks in advance!
Thanks in advance!
Registered User
No one ?
Ok, how about those that gave up the VIP route and turned their car into
a race car or a drift car or a road racer?
I've seen the SUPRA MKIV seats in the JZS147 MKI, they look ok but missing that wow factor.
I'm sure many are also curious how the aftermarket seats would look like in the MK1's.
Anyone...
Recaro, Sparco, MoMo, Tenzo, Bride, other....
Anyone...
Registered User
here you go
working on the interior now.
waiting for matching fabic to do the door panel inserts.
will something interesting to the hood liner.
will be adding other touches to pull together the interior.
info
Sparco Chronos
Sparco seat rails
Sparco Supra seat mounts. only three mount points will line up. You will need a mallet as well. I'll be welding a short extension to the mount points for the front seat monts along the trans tunnel.
Seat Belt is Simmson Platium with CAM lock (5pt) good enought for straightline racing.
going to work on rollcage next so I can run fast and not get kicked off the track. Plus safety and peace of mind.
Will attempt not to loose use of seating in the rear. will go with chromoly tubing to keep the cage low profit and will try to run it close to factory pilliars to try and hide/blend it in.
info
Sparco Chronos
Sparco seat rails
