wtb aftermarket stabilizer bar
Old 07-28-09, 08:18 AM
jdmgs300
jdmgs300's Avatar
Default wtb aftermarket stabilizer bar
hi new to the forum and own a 1993 gs300.. for about two months now .... im looking for a aftermarket stabiilzer bar for the 1g gs300 . looked everywhere with no luck ... my stock one broke on me about a month ago ... snapped by the bushing b4 the links on the passenger side
Old 07-29-09, 08:39 AM
jdmgs300
jdmgs300's Avatar
will the Mark iv supra stabilizer bar fit?
Old 07-30-09, 07:59 AM
Triple C
Triple C's Avatar
Are you taking about your Swaybar?
Old 07-30-09, 09:08 AM
deknick
deknick's Avatar
you must be talking about the sway bar under the car, right?
and not the strut bar?
Old 07-30-09, 09:23 AM
jdmgs300
jdmgs300's Avatar
yes im talkin bout the sway bar , mine snapped at the bushing b4 the linkage on the passenger side
Old 07-30-09, 09:27 AM
deknick
deknick's Avatar
As far as i've been able to find, a/m ones are rare to find, since most of them are usually one off customs, since the GS wasnt' built to track, so stock is usually good for almost all purposes
Old 07-31-09, 06:38 AM
Dan@FSM
Dan@FSM's Avatar
You can fit the rear off a mkiv supra. You need to use the rear subframe mounts from the supra to get it to work.
Old 07-31-09, 07:14 AM
Rising_Sun
Rising_Sun's Avatar
The MKIV rear sway upgrade is the BEST suspension modification for the sloppy 1st gen GS. The front sway bar fits also with the MKIV end links as well.
Old 07-31-09, 10:12 AM
Lexatlast
Lexatlast's Avatar
so a stock or aftermarket rear sway bar for an MKIV supra will fit if we have supra rear subframe mounts???
Sweet... our suspension is poo
ps 900 posts!
Old 07-31-09, 10:35 AM
GoFastTSI
GoFastTSI's Avatar
Believe he meant the rear end link mounts, may be wrong though. Either way I have a set of MKIV bars coming with end links.
GoFastTSI
GoFastTSI's Avatar
Woot for 100th post. Small compared to you guys, but working on it.
Old 07-31-09, 12:49 PM
Xcaliber00
Xcaliber00's Avatar
Cool. Thats next.
Old 07-31-09, 01:47 PM
Dan@FSM
Dan@FSM's Avatar
Front supra bar will not fit. I've already confirmed this. Since we have the different K member it won't fit.
Old 07-31-09, 02:02 PM
trd4life
trd4life's Avatar
So in order to use the supra rear sway bar we need the supra endlinks or the subframe mounts?
Old 07-31-09, 02:37 PM
GoFastTSI
GoFastTSI's Avatar
Are we CERTAIN the front will not fit?
Quick Reply: wtb aftermarket stabilizer bar
