srew supra radiators
Old 08-02-09 | 02:14 PM
gteGS's Avatar
gteGS
Default srew supra radiators
my car, aristo swap full bpu, runs electric fans with a new factory supra radiator. It would constantly over heat expecially with a/c on in town NOT EVEN boosting!
The fans are perma cool 12" dual 1600 cfm each pullers
I got finished installing a factory v8 radiator that my boy ran on his race car. At first look the inlet and outlets look like they would run into the charge pipes.
I finally got around to installing it. I had to cut out some of the frame to get it to fit find a new top radiator hose and build a bracket so it would not touch the drive belt. And I had to extend the hot side intercooler pipe about 2 inches. Now keep in mind im running factory fat *** pipes so everything was tight. and of course I had to make 2 new top brackets and for the bottom I retained the factory mounting locations but used suspension bushings to raise it about a inche allowing me to run the factory hot side intercooler pipe with extention.
The fan setup is a 15in puller no name and a 12" perma cool.
This setup is awesome I can go around town beating on it with a/c on and no overheating.
I can post picture if some on is interested.
Old 08-02-09 | 02:16 PM
GoFastTSI's Avatar
GoFastTSI
I have a Mishimoto radiator with mishimoto radiator pipes, mishimoto trans cooler and two SPAL fans and never overheat. If I had to guess your other radiator had some blockage.
Old 08-02-09 | 02:24 PM
gteGS's Avatar
gteGS
no it was brand new only used it for 3 months. they way I went was low buck but more labor intensive. I spents about 75 in supplies and 75 for the radiator itself so 150 total
Old 08-02-09 | 06:09 PM
celm's Avatar
celm
pics please
Old 08-02-09 | 09:13 PM
trd4life's Avatar
trd4life
I have heard on SF that electric fans dont do well on 2jzgte's. Glad to hear it worked out for you.
Old 08-03-09 | 07:12 AM
GoFastTSI's Avatar
GoFastTSI
No issues with mine in Alabama summer stop and go traffic. I also added Redline Water Wetter as well.
Old 08-03-09 | 05:32 PM
yusef's Avatar
yusef
i have the exact same setup, but mishimoto fans and the car overheats with ac on, and starts to climb when im driving it hard. everything was new so i know theres no blockage.
Old 08-03-09 | 07:18 PM
GoFastTSI's Avatar
GoFastTSI
Did you happen to replace your thermostat? Mine was toast when I pulled it. Also, does your radiator cap hit the hood? I had to cut down the hood support to keep it from hitting the cap and causing coolant to spray. That may be your problem. Also, ensure you don't have any air bubbles by burping the system.
Old 08-05-09 | 04:54 PM
gteGS's Avatar
gteGS
yes i did replace the t stat before the radiator change and bled the system multiple times. I will psot pics soon. The radiator cap does not hit the hood
Old 08-05-09 | 06:22 PM
GoFastTSI's Avatar
GoFastTSI
Sorry, should have quoted, that was in reply to Yusef's post.
SOARER525
Performance & Maintenance
12-15-20 06:17 AM
GoFastTSI
06-04-09 12:54 AM
2JZSoarer
13
09-20-07 10:56 AM
SinisterSC
17
12-01-05 05:17 PM
TerryTCL
Performance
12-20-02 02:54 AM
Quick Reply: srew supra radiators
