Headlights
Hi Guys,
JDM Toyota Aristo Lexus GS300 Headlights 93-97
Maker Toyota
Model Aristo
Chassis JZS147
Category Headlights
My question is will it fit in my car without mod done to it, "plug & play"
My car is Lexus 1995 GS300, no JDM on it.
what is JDM mean? Thanks.
Maker Toyota
Model Aristo
Chassis JZS147
Category Headlights
JDM means
Japanese Domestic Motors.
Ie, all the cars sold in Japan. once exported they can land in Canada if they are odler than 15 years, and in USA if they are older than 25. and are always all Right Hand Drive (RHD)
the lights fit 100% but the wiring i'm not sure, you'll have to ask someone on here who's done it
I got headlights JHOT meant to replace mine but found out that they fit ok but wiring and socket plug were different, it is not plug & play for what I saw it, correct me if i'm wrong on this one, daytime light extra for JDM. How do I make wiring and socket to fit. The connectors are different pinout. Thanks for you replied:
I hope you guys don't get mad on this one. Where do you get this wires from, our first generation don't have daytime lights and do you need to splite all the lights wires. Thanks.
Im not sure, I just went and bought the bulbs and connected it, if you dont, you're going to have one loose wire on the US harness for the turn signal (us-3 wires on turn signal, aristo- 4 wires-2 turn signal/2 DRL) You connect both green wires with black stripes, both white ones, then that black one you see tapped into the white one is the white wire from the DRLs and the green one next to the black on is from the drl. So the green one withouth the black stripe would be left hanging if you didnt connect the drls. And I dont know if your turn signal would work if you left that hanging. But it's easier just connecting it then wondering what would happen if you dont
What do you mean just plug and play, I looked at the connector for each light bulb, they are all different, if I want to keep and use these headlights, I have to cut each OEM connector out and splice it to JDM one. correct me if I'm wrong. Thanks.
JDM means
