rear driver side window went out.
rear driver side window went out. so does anyone know how to take out the door panel so i could assess the damage? the sound of something popping and then metal hitting the door was the worst sound i could ever hear !!! F M L !!!
That is such a common problem on our cars. My rear driver side window also went out a few months ago and got stuck midway so I took the door panel out and had to make a temp stand to hold it up till I got a new regulator.
To take the door panel out there are a few screws around the door panel. Take the window switch out, and there is another screw there. I believe there is another screw behind the light. Also carefully take out the door handle trim ring and then there is 1 last screw. The rest is on clips. There are like 5 clips toward the top of the door panel in a horizontal line that are pretty stout and take some force to get out.
Also check out this thread for some other help
https://www.clublexus.com/forums/gs-...l-removal.html
