Water in trunk
Hi Guys,
I just found out that there is a lot of water in my trunk, I don't know where it came from, the seal around the trunk is good. The water is almost full in my spare tire compartment. Is any one have this problem with 1st GS300 before and what is the symptom. Thanks.
Water in the trunk is a notorious 1GS problem.
Please search in the future - "water in trunk" will bring up lots of threads like this one...
https://www.clublexus.com/forums/gs-...ion-flaws.html
or this one that has the SAME title as your thread...
https://www.clublexus.com/forums/gs-...-in-trunk.html
Good luck with your issue
Hi Guys,
I spent a lot of time tried to find out where got into my trunk. Some suggested check drain hole for sunroof, well I open mine and saw one hole each side in front of it and they weren't plug but when I pour water into it, it drain out to the front behind front wheel. Is there other two holes in behind the sunroof that I couldn't see. I saw two drain holes each of the trunk. Where are these two holes drain from. Please help me. Thanks.
timywong,
Can you see the two back drain holes when you open sunroof? I clean my sunroof very good. How do you know the two back drain holes not plug or disconnectd. Can you pour water into sunroof to see if it run through the drain holes or it would ruin the roof. Thanks.
Hi Guys,
Hi Guys,
My nephew and I spent so much time tried to find out where the water came from. We even took out spare tire out of the trunk. Now we knew where the water came but have no clue how it got there. The water came from the rear frame directly behind spare tire and on the the right side behind the CD changer. We could not figure it how it got out, took weather strip and check look like it is still in good shape. Here is my question "'HAVE ANY ONE REPLACED TRUNK WEATHER STRIP AND FIX THIS WATER LEAK'' I am a little skeptical about it due to how expensive part, check on line, little over $100.00.
topgun129
01-24-10 07:38 PM
