headlamp adjustment ?
ok so i have an old broken headlamp i was just messin with it before i threw it out and i was looking at the long adjustment screw on the bottem of the headlamp, inbetween the low beam and high beam. and i was was turning it both of them moved up and down and because it was broken idk if a normal headlamp would still work the same way. cause my low beams are aimed so low i can only see like 15 feet in front of me. and i often go down country roads. so...could i move that long adjustment screw near the bottem of the lamp between the low and high beams and move my low beams higher?
if im not mistaken you just need to move the screw on top and it will aim it higher. the long one should just do the hi beams not low. im going to go test since i need to adjust mine anyway but i will let you know if it changes for me
just make sure the little level on top is still level and not off the mark
