Help with Fuel System....
I am currently building a 93 GS300, I need some ideas on a Fuel system...I am going to be pushing somewhere around 500hp when done. What size injectors should I go with? Will bigger injectors fit with the stock fuel rail? I can get a fuel rail from Powerhouse racing....But im not really sure how in depth I will need to go for my HP rating...any help and ideas are welcome, even if its things other then the fuel system if you know something I dont please clue me in, This is my first Lexus build so im a newb..
Well......we need a bit more info on your car. Are you going to be running a standalone and are you GE or GTE??
Based in the information thus far:
i wouldn't go with a Walbro, they're noisy and cheap, crappy quality.
The OEM Supra TT pump will be more than enough to support 500, and it's great quality. I doubt you'd ever have to replace it. Is your aim 500 crank or wheel?
For injectors 680's would be good, or you could run stock Supra TT 550's, depends if you need lo/hi impedance, BUT the TT 550's won't work with your PHR top feed rail. I suggest going with a Denso style injector (Sard, HKS, etc). 550's should support 500 crank no problem, if you want 500whp, i suggest going to 680's.
The stock fuel lines are good enough for what you're doing. I'm using an HKS FPR, but there are some decent ones for cheap such as Fuel Lab.
Ditch the fuel pulse regulator and get the bypass line too. Bippu hit it pretty close to perfect on injector sizing, depends on wheels or crank power. It's generally about 1cc per whp on these motors. You don't want to run over 80%. Guys who run over 500 wheels generally start getting into running twin pumps.
Cool thanks for the info guys i have been researching my A$$ off to get this kind of info...I am actually talking to another guy in the Performance section about this....All this info is greatly appretiated and rest assured I will keep you guys updated as the project goes on
it's the same pump as the old HKS racing fuel pump
Yeah, there's no problem running a walbro. Such poor info. How do you expect Supra 550's to fit when they are side feed and the GE motor uses a top feed? Know what your saying before you give advice.
I can set you up with a complete fuel system. I have no own fuel rails and complete systems. FFIM, got that covered too. Email for details. dan@fsmoto.net
