2JZGTE swap RPM question
Old 01-24-10 | 06:21 PM
rush007's Avatar
rush007
Default 2JZGTE swap RPM question
The car is on and running but for some reason the RPM's are not registering. any thoughts? MPH, fuel, and all other gauges are working. I checked the fuse under the hood and they look fine. replaced alt fuse. dont know where else to look.
another question, for those with the turbo experience- what turbo controller would be good to invest in? i was thinking of the eboost2 because of all the things i can do with it but wouldnt mind paying less for something that does just as much and cheaper. i have used manual controllers in the past. also what alarm system is decent with a built in turbo timer?
any help, again, is much appreciated. thanks
Old 01-24-10 | 07:06 PM
147noob's Avatar
147noob
need to jump the resistor in the back of the gauge cluster to make it work there are threads on this its like a ten second fix don't know where it is though saw it a long time ago...
Old 01-24-10 | 07:47 PM
Kaiser's Avatar
Kaiser
Disconnect the cluster and remove. Solder a jumper on the R7 resistor next to the orange plug. Reinstall and viola.
Old 01-24-10 | 10:20 PM
rush007's Avatar
rush007
what do i jump the r7 resistor too? i found this http://forum.clubna-t.com/showthread...light=resistor but cant tell where to solder. anyone have any other pics?
Old 01-25-10 | 06:52 AM
Kaiser's Avatar
Kaiser
A piece of wire that bypasses the resistor.
Old 01-25-10 | 08:34 AM
rush007's Avatar
rush007
okay, so just loop on the resistor. thanks
Old 02-02-10 | 06:53 PM
rush007's Avatar
rush007
one last thing, will this fix the speedometer too?
Old 02-02-10 | 07:28 PM
Kaiser's Avatar
Kaiser
The speedometer should work already.
Old 02-03-10 | 10:51 AM
rush007's Avatar
rush007
i thought it was working before but then now that i look at it, it isn't. is there anything i should look for specifically? i'm going to search the site too for additional help. how do i know if the needle is broken?
Old 02-03-10 | 12:21 PM
Is300Tree2's Avatar
Is300Tree2
Rush...would you happen to have a pic of the area of the harness you had to extend?
Old 02-03-10 | 12:44 PM
rush007's Avatar
rush007
actually i dont. i could take one but really it could be anywhere between the engine and cpu plug. i extended from the area that goes into the firewall.
davyjordi
10-17-17 08:12 PM
Volume123
Performance & Maintenance
12
02-09-13 03:51 AM
adk1315
11-08-10 12:23 AM
vindedreal
06-04-08 11:44 AM
