Engine Swap 911 Help please!! I will pay money!!
Hi guys I swapped engines in my 93 GS Myself.
The are car starts but idles poorly. The exhauset fumes are unbearable. I actually have to adjust the throttle cable to keep the car running. I am fouling plugs. All of them look fouled and I have replaced them twice. I have swapped out 3 different ecu's and I have the same issue. I have swapped iac, tps, egr, chcked vac lines, confirmed timing, checked distub cap a million times. I have checked and re-checked the timing. And to top all of this off now I'm leaking oil from the bottom of the crankshaft. I am not sure if it is the crank seal or the oil pump.
CAN SOME ONE PLEASE HELP ME !!!!!!!!!!!!! I WILL PAY $$ TO WHO EVER CAN HELP ME.....!!!!!!!!!!!1
Hey what's Kaiser, I thank you for chiming in. You seem to one of the few people on the forum that is willing help people. I respect that alot....
Yes I did a pressure test and it tested good. 150-160psi cold....
all of my plugs are fouled. I have changed them a few times already...
You mentioned that you had to repair you O2 sensor in another post. I've never been able to successfully solder an 02 and have it accurate. I've seen others that have, but they are based on a millivolt system so they are very sensitive. Have you tried starting the motor with the 02 unplugged? I believe there should be a base map to run the car in the ECU. At the very least we are looking for some kind of change. After that try it with the Karmen unplugged.
Yes I have all of the teeth on the reluctor.
Hey Kaiser,
thanks for reaching out to help me... I appreciate that my friend. I just got my timing light not to long ago. I will try to use it in a while. Stay tuned...
Hey Jeff thanks for reaching out to help. I grounded the engine with jumper cables. It didn't work. I will keep trying. Stay tuned....
Thanks Man
Thanks Man
Ramzy0
06-02-19 03:36 PM
frank12933
10-24-17 07:00 PM
