Interchangable Suspension Parts: Parts that work on our chassis.
Old 03-09-10, 10:53 AM
jmax.garage
jmax.garage's Avatar
Default Interchangable Suspension Parts: Parts that work on our chassis.
I think something like this has been delayed for a while, so I will take the initiative.
Here is a list of adjustable suspension parts that can be interchanged:
Parts from other platforms: CONFIRMED
-RCA's from 2nd Gen Aristo/GS Night Pager RCA's
-Front Upper Adjustable Arms from 2nd Gen Aristo/GS
-Front Spindle from X90,100,110-IS300-2nd Gen Aristo/GS
-Inner Tie Rod: JZZ30
-Ball Joint: JZS160
-Rear Swaybar Links: JZZ30
Parts from other platforms: UNCONFIRMED/IN TESTING-THEORY
-Front Lower Arm: X90 and IS300
-Front Tension Rod: X90 and IS300
-Rear Lower Arm: UZZ40-JZX110-SXE10-JZS161
-Rear Toe Arm: IS300
-Rear Sway bar and end links: Supra TT MKIV <--Unlikely, parts do not come close to stock ones. Only an installation picture set will confirm this.
-Rear camber bolt: 93~96 Camry/ES300
IF YOU KNOW MORE, PLEASE UPDATE THE LIST WITH PICS.
Thanks to RockAuto fro the pics and part numbers.
Parts comparison per vehicle. All parts shown are right side. If a model is missing from the picture set is because the part never even came close to look like a JZS147 part.
Inner Tie Rod
Outer Tie Rod
Upper Control Arm
Lower Control Arm
Ball Joint
Front Sway Bar Links
the gold one is from a JZA80
Rear Sway Bar Links
As soon as I get some parts I will start posting pics. Lets make this list the best list on the internet!
Update:
Heres something that hasn't been discussed! the rear RUCAs from the same year range SC/ soarers has the same part number (48770) as the JZS147.
94 SC300 rear suspension diagram:
http://www.lexuspartsnow.com/Page_Pr...igPicture=True
96 GS300 rear suspension diagram:
http://www.lexuspartsnow.com/compone...8-04-1634.html
Thanks CubanGS!!!
Supra Upper Rear Control Arms confirmed by CubanGS:
SC toe and trac links confirmed by CubanGS:
http://battleversion.com/store/battl...exus/sc-91-00/
It would be cool if a mod would sticky this as well.
File Type: jpg
UZS143 (03-15-22)
Old 03-09-10, 12:55 PM
GS300 I6
GS300 I6's Avatar
+1 sticky
Old 03-09-10, 02:13 PM
jmax.garage
One interesting setup I found: shortening the spindle 20mm, adding RCA's, then raise the coilover back up to set the suspension the geometry back to stock.
Benefits: lowering the car about 20mm without affecting the suspension's gemoetry
metal_dokan-img600x450-1265460252dx.jpg?t=1268156006
Also this is what RCA's are for:
Thanks for T3 for the pic!
Old 03-09-10, 03:14 PM
147noob
147noob's Avatar
what about jza80/sc300 do thier tie rods work on our cars
Old 03-10-10, 07:25 AM
jmax.garage
as far as I know, no.
IS300 rear tie rods are a perfect fit; will get my megan ones next week to post pics and move it out of the UNCONFIRMED list.
I'm going to try the fronts next with IS300 ones after I can get more money from paint jobs LOL
Old 03-10-10, 07:45 AM
GoFastTSI
GoFastTSI's Avatar
Supra TT Rear Sway bar and end links.
Old 03-10-10, 11:31 AM
jmax.garage
GoFast, do you have pics? That would help a great deal! Thanks!
Old 03-10-10, 04:23 PM
mkiiisupra
mkiiisupra's Avatar
Pictures? seems worth-while for the right price.
Old 03-11-10, 05:19 PM
Dan@FSM
Dan@FSM's Avatar
The Supra TT rear sway will fit but will also need the control arm mounts. Front is definitely a no-go.
Old 03-16-10, 01:03 PM
jmax.garage
Updated list.
Old 03-17-10, 04:07 AM
wayne
wayne's Avatar
What about SC and Supra coilovers?
Old 03-17-10, 10:44 AM
jmax.garage
JZA80's and JZZ30's (Supra and Soarers) front coilovers fit, the rears need to be modified from the Supra; i dont know about the Soarers/SC rears. The downside of these coilovers is that the damping is a bit harsher and the coilover itself is way shorter than a coilover made specifically for our big heavy cars. If u want a car so slammed and rigid that is very hard to drive as a DD, go with these coilovers. I had Teins froma MKIV for about 6 months and I hated I couldn't raise the car enough to drive comfortably.
Indeed, I will include them in the list.
Old 03-29-10, 06:18 AM
jmax.garage
man... no sticky? so no one wants this list? I'm taking this to list my website.
Old 03-29-10, 07:57 PM
1stGS30
1stGS30's Avatar
good thread should be a sticky just like a few others that never make it idk why..
Old 03-29-10, 11:07 PM
147noob
147noob's Avatar
x3 on the sticky
Quick Reply: Interchangable Suspension Parts: Parts that work on our chassis.
