no antenna movement!!!
no antenna movement!!! EDIT: the IN-DEPTH EWD!!!
i just installed the eclipse avn6620 in my car and i had the wiring diagram. everything works great...besides the radio ant. i tried all three wires, then just the black with white stripe. nothing still. all the was done from behind the deck, does anyone know how to get it working?
EDIT: ok so i found the EWD for the auto ant. let me know what you guys think would be the best way to wire it up to an aftermarket deck!!!!
Bump bump bump
-doing all the behind the deck with the R3 connector-
i think splicing the red/green 'amp' wire with the black/white 'ant+b' together and then connect that do your ant lead coming FROM your deck should make the ant. go up....right?
Rit&Booner
03-08-03 01:00 PM
gompka
01-19-03 01:21 AM
