One Piece / Two Piece Headlamps
Does anybody know the major differences between the one piece and two piece headlamps? i.e. Aristo JDM type ones vs. GS300 glass headlamp / seperate corner lamp.
I would assume they are interchangable with minor changes to their mounting bolts?
I have got an ex-Singapore (i think) car in NZ and need to change a headlamp before its next inspection and can't get a glass headlamp so am considering changing both out to Aristo one piece lamps (these are more readily available).
Anyone got any thoughts on this?
Ever better, if someone had some out of a car, would you mind posting some pics of the mounts etc??
Thanks
Thanks
think the glass ones are euro spec? the aristo and usdm gs300 bolts up. the headlight bulb are just different. the usdm gs300 uses a 9006 bulb and the aristo uses a 9005. the only difference with the JDM aristo headlights are their is daytime running lights and also the side has a part that sticks out a bit.
