My window wont go up!!?!
It gos down fine but will not go up at all. the master back window switch cant control anything on my back pasanger window but all other windows work fine form it. but the back passanger window that wont go up the switch works fine. if anyone can help me on whats goin on before i destroy my door please let me know asap. thank you.
The driver's master window control failure is common in the 2GS and not as common in the 1GS. It's odd that you can put the driver's window down but not up. Usually, this problem causes the switch to fail completely. If you can get a cheap, used switch and test it to see if it works, that may be your best bet. As far as wiring, I am no electrician, so I can't be of much help with that.
