Do you really know what is installed on your GS?
FIRST OFF I AM NOT BLAMING THE SELLER FOR STATING ALL OF THE THINGS THAT ARE WRONG. I THINK IT WAS A MISCOMMUNICATION/LYING ON SOME OTHER SELLERS BASIS. THIS CAR HAS CHANGED HANDS A LOT RECENTLY
Okay so I just wanted to post this as a warning. I had this car back a few months ago. It looks different but the vin shows I was an owner, its got the front tint removed because of cops here, its got my motor and everything.
This is what it really has done to it....
2JZ-GTE Single Turbonetics 60-1
HKS Style Wastegate,
2.5" Custom IC Piping,
Large Front Mount Intercooler,
All Silicone Couplers and T-Bolt Clamps,
NGK Wideband O2,
Greddy Emanage
(Tuned by RLZ Engineering -403 whp @ 14psi 93 octane),
Underdrive Pulleys,
Twin Electric Cooling Fans,
Apexi EL Mechanical Boost Gauge,
3" Custom Exhaust, Megan Racing Mufflers,
6000K HID's,
Lowered on Eibach Springs,
Fresh alignment,
Purple 550cc injectors,
Cross drilled and slotted rotors,
New alternator,
New Front lower ball joints,
New timing belt,
New Water pump,
New Front main and cam seals,
Oil pan gasket,
All less than 5k miles ago.
These are the pics from when I had the car.
This is what he posted on eBay. I just found it before it ended.
http://cgi.ebay.com/ebaymotors/95-LE...e0c#vi-content
This is apparently what it has.......which it doesnt.....
Um, last time I checked, I installed the Titan cam gears......
Just makes me think twice about buying cars from someone....
Thought I would share.
NGK Wideband O2,
Greddy Emanage
Underdrive Pulleys,
6000K HID's,
Fresh alignment,
New alternator,
New timing belt,
New Water pump,
Oil pan gasket,
Tan Leather and Black Suede Katzkin ($1000) seats, Custom fitted double stitched.
NEW STERN 19"x9.5" Wheels with 275/30/19 Tires in Rear 19"X8.5" Wheels with 245/35/19 Tires in Front $2000
Replaced the rack and pinion with a brand new one and new ball joints and suspension bushings. $700
97 Aristo 2JZGTE TWIN TURBO front clip and transmission. $3800. You can't get clips anymore.
720cc Greddy side feed injectors. (light blue top) $500
Custom front mount intercooler with polished aluminum piping. $400
HKS Series 3 Super Sequential Blow Off Valve. Welded on the Intercooler piping before the Turbo. $200
Custom dyno tuning by Hux Racing via Greddy E manage. $500
Rev limit set to 6.5k rpms to keep the engine safe and reliable.
Single denso supra TT fuel pump. $250
Stainless custom Turbo Manifold. $500
Garrett bb 60mm turbo with oil and water cooling. $1100
3" custom downpipe. $350
Apexi boost gauge $300
Custom bent water lines. A/n stainless oil lines. $300
44mm Tial deltagate. $500
Dual Electric Fans wired in parrallel $200
DEI 2000 degree carbon kevlar turbo blanket(helps effieciency and decreases spool time.) $200
Custom air intake with K&N air filter. $100
Custom made slip fit dual catback exhaust. $700
New Eibach springs/Monroe sensatrac shocks. $500 THIS SUSPENSION RIDES SO NICE JUST LIKE A LEXUS SHOULD. LOVE IT.
Plx wideband. . $350
Samco oil and transmission cooler. $300
Slotted and Cross drilled brake rotors. Upgraded pads. $500
Jdm aristo front grill. $200
Aristo rear taillight garnish. Aristo Badges. $200
8k Hid low beams. Stock high beams. $200
At 50k miles replaced the water pump, alternator, oil pump, serpentine belt, and timing belt. $500
Hux Racing installed a cometic metal head gasket, arp headstuds and Titan Motorsports cam gears. $400
LocknRoll
Performance & Maintenance
04-06-06 10:53 AM
