My 1st gen G introduction
#49
Since my last post on here the engine developed rod knock. So I parked it and pulled the motor.
New low milege jdm engine from attarco should be here tomorow.
New parts list:
Hks super sequential BOV
2.5 intercooler kit
Driftmotion t series turbo fittings
Cool it exhaust wrap
Transmission filter and royal purple atf fluid
More pics tomorow
New parts list:
2.5 intercooler kit
More pics tomorow
#52
Got it on ebay last year for around 300 without fogs. Saw one the other day for about 350 check it out.
#53
progress
Motor arved today. Everything on the motor checked out ok, my one complaint is they spray painted parts of the engine silver and black to make it look newer. o well, I would diffenently order from them again.
5 hours later I got the harness swapped over, throttle body swapped, trans and torque converter mounted.
This also showed up today.
#54
Why did you go with another ge motor? What was the price difference between the motor you got and the tt aristo motor? Also did you shim the actuators on the tranny while you have it out?
#55
No I didn't shim it, what will that do? Herd of people having Problems with the tranny not shifting at high rpm after the turbo swap. Would this help?
#56
yes the non-shifting is one reason i have seen members do this mod, here is a post of another member asking the same question (kinda) and the feedback he gets should tell you all you need to know about it. i plan on doing it when i go na-t, btw where in texas are you?? im in austin.
https://www.clublexus.com/forums/per...peed-a340.html
#57
Im located just south of fort worth.
#58
Its been a while here is where the gs stands.
upgrades since last post:
aristo garnish
t70 garrett ball bearing
Volk lug nuts
finaly got my bent rim refinished and back on
also did some drifting.
aristo garnish
Volk lug nuts
