Question!!!!!!
OK so i installed a new window motor and regulator but the window still only goes down....... and not up. all the switches on the driver master swtich works fine but the switch to the window im working on. from the master switch if gives no signal to the window but from the window im working on i can roll it down but no up. do you think that the master switch could be the problem? or am i going to have to trace all the wires back to the master switch to see if any are broken?
I've seen in some other posts that sometimes the wires that go from the door to the inside of the car break. They're in that little baffled rubber boot that you can see when the door is open. I'd start looking there
05ls430518
02-26-18 08:40 AM
