nakamichi removal and aftermarket install.
I hate to be the dude to repost something that may have already been posted, but i cant find it for nothing. I just got a tv deck that i need to install but was informed by local stereo venders best buy, radio lab noisegate that they dont make a wiringharness for aftermarket applications. I seen someone put a full diagram for the pioneer factory deck removal, but not a nakamichi. Can anyone help me out?
i had the same problem installing my Pioneer P3200BT about a month or two ago....couldn't find anything (worth using). Yes, it is true, they don't make a wiring harness. My install guy basically had to go the traditional route and test each wire until he figured it out. It took him about 3 or 4 hours.
Good luck!
Good luck!
I actually just installed the same deck as SKIIP, Pioneer AVH-P3200BT in my 1GS. It was pretty easy actually. There actually isn't a wire harness due to the stock amp and the way the stereo wiring was set up. I used the DIY guide to install my deck. All you have to do is run speaker wires from the back of the trunk to your head unit in the front, then get your power source from one of the plugs that used to plug in to the stock unit. My unit is a Nakamichi so I don't know how much of a difference it is compared to the factory pioneer. But install was easy!
Thanx for the insight. I think I found a harness that works thanx to !gs30. It stil requires a little splicing but not as much. Will let u guys know when project is compete.
wwillmon
07-23-18 01:38 AM
92GreenSC400
03-04-04 09:32 PM
