overheating help
well okay i own a 1994 lexus gs300 and i just recently changed the headgasket on the car, cars thermostat has been removed too and radiator hoses have been changed, but the car keeps moving up when im stopped and when i go the needel drops back down again sometimes when im stopped it doesnt move i dont get it, the water pump seems like its been changed but im going to change the water pump asap does anyone think of anything else it could be thanks
burp it, the way me and my bro did it when we had old supras, we jacked up the front end, took off the radiator cap, and just ran the car for a few minutes.
check your radiator cap. i had a few faulty radiator caps that would cause the temp to fluctuate.
Your car has coolant running continuously when you remove the thermostat but I just replaced mine, only $15 to fix.
With the car off, check you fan clutch by spinning the fan, if it spins freely you probably need a new one, if it barely spins it's fine.
