Oil drip
Oil drip
I've been noticing my car has been leaking a little bit of oil. It doesn't bother me and it doesn't leak enough where I constantly have to refill my oil, but it is leaving little dots or drops of oil where I park.
Any suggestions on where to look or how to fix?
Thanks
Thanks
clean the engine (steam) top and bottom (under carage) then keep an open eye. There is also a blue or red die to put in with the oil so that you may spot the leak.
mike in rancho
mike in rancho
If it's from the rear of the engine, most likely valve cover gasket.
If it's from the front, most likely the distributor o-ring or the distributor itself. Both my GS and SC are leaking oil from inside the distributor. To verify this, you can see oil residue on the heat shield under the distributor.
