fuel pump dead????
my 96 gs is has no power and doesnt want to go past 2000 rpm in gear.
checked fuel pump resitance and got 1.2ohms (specs are 0.2-3) not sure about pressure but i went to the tank today and the pump is making noise and it sometimes go up and down? could it be dying even though the specs are right?
check engine is on code is p0171 for lean engine running
i am very much sure it has to do with fuel but cant figure out if its the pump,ecu, fuel pump ecu or the fuel pressure regulator.
fuel filter was changed a month ago
LoveSCs
Performance & Maintenance
11-04-21 11:41 PM
Modenaro
29
12-11-18 08:47 AM
