Front Door, Driver's Side
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
calm down there. Mines just the same, but it's just misaligned from sloppy body work during the previous owners possession. Just sit down one saturday and tinker with it. It helps having 2 people so one can support the door while you're adjusting it. Just loosen the 2 hinges that hold the door and you may have to adjust the latch. I've just been too lazy but I'll get too it, along with other little things, this summer since the weathers JUST now getting nice in the NW. But 1 door not being aligned doesnt mean the cars falling apart, if anything buy a new door from a junkyard and put it on the car rather then putting the car in the junkyard.
With a #1 philips screw driver. Loosen the screws and move the strike in a little, tighten the screws.
Test the door for closure and do it again if the door isnt shut all the way.
There are also small rubber bumpers on the inner door skin that can be adjusted if they are preventing the door from closing all the way after you adjust the strike.
