Helpppppp!!! Needed bad!!
ok so the story behind my gs is the alarm system and radio is acting up .. the larm will go off randomly and when i pull the key from the ignition the radio stay on and cut off for about 3 second and comes back on.. by the way its a pioneer aftermarket radio .. never had the problem before ... the alarm was acting up last weekend i pulled the battery for a couple hour and tried searchin for a bad ground but could find any search continues again..... any help will be really appreciated i now cant lock my car cause alarm will go off every so often ... by the way its a 1993 gs300 fully loaded
your problem is hard to diagnose in a forum. might be the module that keeps accessory power on after key removal for 30 secs. check your door switch for alarm. if aftermarket alarm, you will need to check most wires you plugged. something is probably doing a short or loose...good luck
Some cheap alarm systems have a fuse you can pull located near the "ECU" of the alarm. Most installers place it under the driver side kick panel which is just above the pedals. Try pulling it out if it even has one, then try starting it. If it works for you remember that by pulling the fuse you disable the alarm.
sld
06-05-03 08:20 AM
