Car shakes at Highway speeds
Ok so my problem has been that on highway speeds the body of the car shakes violently ( actually not too bad since new tires but still bad) and it stops if i slow down a lil bit then continue on. But it happens over bumps, crosswinds, etc. Ive checked the car and have play side to side at both front wheels and at the rear wheels theres play up and down. Im gonna start with the rear control arms unless someone else had any similar problems. ANd i meant rear upper control arms. Found some used on ebay for 50 a peice.
i have the same problem in my car.First i thought maybe my tires where just off balance but after looking into it some more i found that was not the problem.I think i am gonna start with my fronts that where it seems to be the worst at.
The main part that is connected to the body of the car is the control arms. Esp. in the rear they are right with the body. My tie rods are toast too but i cnt see that makin the car sway. The control arms in the front when they go bad your wheel will kinda jerk when you stop. Hope that helps both of us out! lol
p.s. I went to Delaware State. Almost played basketball for them.
Check the tie rods, control arms, ball joints. If they are in good condition look at the cv joint, does it feel worn out? If you turn your wheel all the way to the right and hit the throttle does you hear a clicking sound? If so, it's the CV Joint.
Thanks for the help but if you read my post i was talking about body sway. The only thing a worn out CV joint would do is as you said " click when turning". Thanks anyway. But i have checked all as mentioned earlier in my post.
Hey guys, hope this helps. I had the same problem as far as the car sway at freeway speeds when going over a bump! it got kinda scary at times but checked everything and i finally changed my shocks all 4 and it stopped swaying that's just my experience hope this helps.
Sounds like shocks to me. We ended up having bad front ball joints and worn tires...after replacing those it was a little better but still there. Turned out one or more of the stock wheels was bent...but that was vibration, not sway like whats been mentioned. Our is starting to sway like this now too, and I noticed our rear strut cartridges are about gone when I replaced the springs a year ago.
Ok i hear ya...but just think about it...my car is shaking SIDEWAYS. I could understand the shocks if i was bottoming out on bumps or bouncing but its strictly left to right. Also I feel the right wheel bouncing up and down alot like a bad ball joint when im making hard left turns.
Am having the same problem with my 96 Lexus GS300. When I am on the streets and go over a bump my GS sways left and right also when I am on the freeway.
Went ahead and lifted the front of the GS and noticed that the steering damper was missing. I just recently bought this Lexus a few weeks ago. The steering damper is attached to the rack & pinion. I am taking the GS in to have the steering damper replaced and am hoping this will solve the problem.
After reading HyperVish's post
Here is the Toyota/Lexus GS300(1st gen) ball joint recall documents. check and see if your VIN # is in the affected vehicles.
http://nhthqnwws112.odi.nhtsa.dot.go...romPublic=true
out of maybe for example I think out of 32,000 in the first years 27,000 were affected where the ball joint would split apart rendering the car useless until fixed not to mention the body work damage.
(Mine just separated not too long ago, and I was lucky I was at a stop....Picture your car sitting on its underframe)
Report Date: September 8, 2010 at 11:31 AM
Search Type: VEHICLE
Make: LEXUS
Model: GS300
Model Year: 1994
Results : 1 | All records displayed
Make: LEXUS Model: GS300
Model Year: 1994
Manufacturer: TOYOTA MOTOR CO., LTD. Mfr's Report Date: MAR 28, 1995
NHTSA CAMPAIGN ID Number: 95V072000
N/A
NHTSA Action Number: N/A
Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
Potential Number of Units Affected: 27604
Summary:
THE SPHERICAL PORTIONS OF CERTAIN LOWER BALL JOINTS HAD FINISHED SURFACES THAT WERE NOT SMOOTH CAUSING FRICTION WITH THE SURFACE OF THE BALL JOINT CAP.
Consequence:
THIS CONDITION CAN LEAD TO SEPARATION OF THE BALLJOINT INCREASING THE POTENTIAL FOR A VEHICLE ACCIDENT.
Remedy:
DEALERS WILL REPLACE THE LOWER BALL JOINTS ON THE AFFECTED VEHICLES.
Notes:
SYSTEM: SUSPENSION; INDEPENDENT FRONT CONTROL ARM; LOWER; BALL JOINT. VEHICLE DESCRIPTION: PASSENGER VEHICLES. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME, PLEASE CONTACT TOYOTA 1-800-255-3987. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
Check to Request Research. Submit below.
Make: LEXUS
Model: GS300
Model Year: 1994
Model Year: 1994
N/A
Summary:
Consequence:
Remedy:
Notes:
After driving for a while have you checked if any of your rotors are hotter than the others on one side or the other? Caliper sliding pin siezed causing one wheel to meet resistance and not turning in sync with another?
....my complaint is body roll/shaking. I've delt with a sticking caliper plenty of times and never felt body roll. Are you guessing BinaryJay? OR have you had that persoanly happen. THe main culpret here is suspension.
