Did Intake Mod now CEL
Old 09-08-10, 05:37 AM
Is300Tree2
Is300Tree2's Avatar
Default Did Intake Mod now CEL
Ok so I did a custom intake with an adapter from pep boys and one of there generic air filters. No im getting a hesitation, bucking, and all kinds of crazy codes like, vaf circuit, IAT circuit, turbocharger pressure ?!!?!?! WTF! ?
It looks just like this guys except my filter is a tad bit shorter. Not much though. I have everything hooked up properly, and I even tried cleaning my MAF after this happened and no change.
https://www.clublexus.com/forums/gs-...-complete.html
Old 09-08-10, 06:32 AM
BinaryJay
BinaryJay's Avatar
Did you try disconnecting your battery for a while to reset your ECU? This is kind of a normal thing if you change the intake properties too much it's probably putting your air flow readings out of the range that the ECU expects is normal. Resetting it MAY make it re-learn what normal is, but it's a long shot. The easiest and cheapest method is probably putting it back the way you found it.
Old 09-08-10, 08:08 AM
Is300Tree2
Is300Tree2's Avatar
I feel you on resseting the ecu but my thing is so many other members have done this mod with no problems. Maybe my MAF is just goin up i dunno but im sure someone has had this happen, even if by accident.
Old 09-08-10, 09:11 AM
BinaryJay
BinaryJay's Avatar
Well you had to have removed the MAF to do the intake mod, in doing so you may have damaged it by accident. One thing you can try is just pulling the harness and reseating it. If you have some electrical contact cleaner you might want to give the harnesses a few squirts, let dry, and then reconnect and try again.
Old 09-08-10, 10:47 AM
Is300Tree2
Is300Tree2's Avatar
Yea...well ima put it back to stock and see what happens. If it acts the same i'll know the MAF is bad. I'll update when I get off work.
Old 09-08-10, 08:36 PM
VIP_Dreamz
VIP_Dreamz's Avatar
wait? what did you use to clean the maf sensor? also did you spray the maf sensor while the engine was still hot? I ask because it is possible the cleaner could of damaged the maf sensor.
Old 09-08-10, 08:57 PM
resen323
resen323's Avatar
if you cleaned the MAF sensor. then there is your problem... i did the same thing and i could not get the car to run right after that. i had to replace the sensor....
Old 09-09-10, 06:34 AM
Is300Tree2
Is300Tree2's Avatar
And I cleaned it with the proper solvent, MAF cleaner.
Update: The car is now back to stock and running like normal. Im gonna do the BFI mod and see how that performs. I think the intake iu used was too short...? I guess.
Old 09-09-10, 06:46 AM
Kaiser
Kaiser's Avatar
You cannot clean a Karmen sensor with any solvents. It destroys them. If yours still works you were extremely lucky.
Old 09-09-10, 08:04 PM
resen323
resen323's Avatar
yeah you were very lucky....
Old 09-10-10, 08:35 AM
Is300Tree2
Is300Tree2's Avatar
oh....didnt know this specific sensor could not be cleaned i've cleaned other MAfs like a nissan one and it only needed to air dry after cleaning....just learned something. Well ima get a new sensor and try the intake again.
Old 09-10-10, 09:57 PM
VIP_Dreamz
VIP_Dreamz's Avatar
yup never use cleaner or maf cleaner to clean toyota maf's. they are very sensitive. I learned the hard way when I messd up my maf when i had an 89 supra turbo.
Old 09-11-10, 09:24 AM
Is300Tree2
Is300Tree2's Avatar
So when you messed it up what symptons came from doin that?
Old 09-11-10, 10:31 AM
GS300 I6
GS300 I6's Avatar
the car doesnt start at all if you clean it. I cleaned my afm with maf cleaner a few months ago and died. thanks kaiser for the info last time. I've learned my lesson.
Old 09-13-10, 05:58 AM
jmax.garage
jmax.garage's Avatar
I think your intake was a bit short. I modified using a DIY kit from PEP boys but tried to keep the length of the tube as long as the stock tube; never had a problem. Try lengthening the intake tube, maybe it will work for you this time?
g/l
Quick Reply: Did Intake Mod now CEL
