SC300 Motor????
SC300 Motor????
Hey guys i just got a complete 2jzge from a sc300 with trans and harness.
I was wondering if its a direct replacement?? the exhaust manifold looks different, as anyone else done this and if so what did you have to change over from the gs motor?? finally gonna get my car running right so i can continue with the project. thanks guys
you will need to replace oil pan and oil pickup tube,also maybe harness if original motor has traction control or not. Did one last year and had to replace the harnass.I would reuse the original stuff. remove upper intake with throttle body and complete harness.Sc tranny tail shaft is different,will not work.
hey guys i really need your help!!! i'm in the process of changing out my motor and putting the sc300 engine and as i was taking my wire harness out i realized its completely different, does that mean i have to change the harness from my motor to the other one and is it all going to just plug in???
Slow_Sc3
SC400 / 300 Classifieds
01-25-13 05:54 AM
bighead222
Performance & Maintenance
02-11-12 06:04 PM
