yeah an SLD has nothing to do with the fuel system at all. you're probably mixing up the SLD with the FCD (fuel cut defencer) which prevents fuel cut once you boost above 14 psi
Yes it's okay to run stock fuel with a SLD or cut pink wire. I have a Toyota Cressida with a 1JZ swap running an SLD, not an Aristo, but it's pretty much the same thing.
