aristo governed at 120mph. how do I get rid of it?
So last night I found out that my aristo motor is unfortunately governed at 120mph. Was wondering what's a good way to get rid of the governor? I am running epik's old twin k26 turbo set up and still on stock tranny. what's a better bcc to get? greddy or hks? or is there a better option such as upgraded ecu that gets rid of boost cut and fuel cut and speed governor all in one?
My friend who was the previous owner and wiring expert said just cut the pink wire but it can possibly throw a code. I rather be safe, since I still need to upgrade the fuel system. guess the sld is safest way to go?
oh ok. well i own an Aristo and one way around the speed limiter is to remove the traction control fuse because its connected to the same circuit? should give it a try if you have traction control
is the sld plug and play? I know they have a hks type 2 sld and then the greddy. which one is the better out of the two? greddy's sld is sold for a better deal. also is it safe to run an sld on the stock fuel system?
