Need help with 93 gs300
Old 10-21-10, 10:51 PM
frediv
frediv's Avatar
Exclamation Need help with 93 gs300
I bought a 1993 GS300 on aug 22nd and it ran perfectly until about 2 weeks ago it began to shut off while driving for no reason. My mechanic said it was some bad relays so he replaced them. Now it will start but only run for a couple miles and then the engine will shut off and i will have to pull out the efi and ig2 relays and put them back in for it to start up again. My mechanic thinks it may be a short somwhere but im not sure. Id appreciate any advice or help as to what this could be and how it can be fixed. Thanks.
Old 10-21-10, 11:48 PM
KingpiN.SC
KingpiN.SC's Avatar
Sounds like you have a short somewhere. I would check for a bad fuel pump ecu as well..
Old 10-22-10, 01:51 PM
frediv
frediv's Avatar
if it is a short, how do you check or how much does it cost to be checked?
Old 10-22-10, 03:16 PM
KingpiN.SC
KingpiN.SC's Avatar
Depends on where it is and how easy it is to get to. Electrical work can get expensive very quickly. I would look towards any aftermarket electronics first, and then examine the wiring near the main and fuel pump ecu's. I'd also check that all of the fuses in your fusebox are the correct amps.
Old 10-22-10, 07:03 PM
jrARISTO
jrARISTO's Avatar
im having the same issue check out my post it mite help you a little
Old 10-23-10, 06:09 PM
frediv
frediv's Avatar
i think ive found a good mechanic thats gonna take a look and attempt to find the short. Thanks guys appreciate the advice.
dsisoutham
01-18-16 03:16 PM
Arnoldg
11-11-15 01:51 PM
Bbruno
11-03-14 11:20 AM
bagg
09-14-13 05:34 PM
running4s
06-08-13 08:26 PM
Quick Reply: Need help with 93 gs300
