02 sensor gte swap
02 sensor gte swap
ok so its my second time about to complete the gte swap wasnt there to finish it off the first time .. but does the o2 sensor from the ge work on the aristo gte swap?
Nope not at all. The Aristo uses a special 3 wire O2. I tried Denso USA and could not source one. I had to go to Supra Forums and find someone who converted to a US harness and buy his sensor.
i foundg another option use the aem wideband sensor and splice it to work with the teh o2 sensor wire .. juss by adding extra wire so i was told ... will see how it goes
just buy any 3 wire o2 sensor. They are all the same, just the ends are different (ie, they read the same voltage). find a cheap 3 wire (like an old chrysler minivan or something), cut off the 2 factory ends, solder yours to the new o2, voila.
the only prob wit that is my downpipe is the bung style flange for the o2 n not the bolt .. so a 7mgte one wouldnt work i did consider gettin another 3 wire bosh one .. any downfall in using the aem wideband as the factory o2sensor also?
