car vibrating inbetween 20' and 40' miles mph
Old 11-28-10 | 10:15 AM
dadude's Avatar
dadude
Question car vibrating inbetween 20' and 40' miles mph
any answers, the car drives and shifts fine but when i slow down to anywere from 40 to 20 mph i get a vibrating from the floor what is that? i thought i need a tune up but if i needed that the rpm gauge would not be steady, thats not happening. its kind of like the car has bad gas or a spark plug is missing.
Old 11-28-10 | 12:07 PM
rapollon's Avatar
rapollon
trying to figure out the same for my car, won't be able to do any work on it til spring. I think my culprit are the engine, tranny and diff mounts. Does your car vibrate while coasting in neutral?
Old 12-01-10 | 02:02 PM
dadude's Avatar
dadude
dont know but i will try that and get back to u but that is funny because i just had my tranny serviced not to long ago and that is when it started happening.
Old 12-01-10 | 02:04 PM
dadude's Avatar
dadude
hit me up 2052762515
Old 12-06-10 | 10:58 AM
BKLEX's Avatar
BKLEX
This was happening to mine at one point. The culprit---upper ball joints! Also, check shocks, struts and also lower ball joints.
The other occasion that this happened to me, a spark plug popped out of place as you first mentioned. Once re-inserted, it was fine and never happened again.
It may not be your issue, but they are all worth checking.
Old 12-07-10 | 01:24 AM
147noob's Avatar
147noob
try checking the driveshaft center piece and the bolts that connect to the diff
Old 12-08-10 | 12:38 AM
RedSC's Avatar
RedSC
Default car
has anyone found out why our cars do this mine does it too???
Lukas99GS
07-27-14 10:40 AM
Gotmerk2
01-14-13 10:09 PM
nysupraman
Performance & Maintenance
09-16-08 06:24 PM
Jewel707
11-04-07 10:21 PM
JeffTsai
Suspension and Brakes
20
05-13-07 10:04 PM
