5 speed write up?
Any one have a write up on this, I didn't see it on DIY
What transmissions can I use? I assume flywheel will be out of what tranny i use.
Will i have to modify a tranny mount?
How will the ecu react?
Drive shaft?
etc etc.
Drive shaft?
etc etc.
okayyyy
Trans- V-160 6sp turbo trans, R-154 5sp turbo trans, W-58 5sp non-turbo trans can be used. All from various year Supras for the most part.
Tranny Mount- I used the same R-154 trans and all I did was flip the R-154 mount backwards and it pretty much lined up.
Ecu- no clue... as Im running a standalone. Altho I do remember Supra guys doing manual swaps and still running the auto ECU. Just have to by-pass neutral start or something.
Driveshaft- custom... spline from tranny rear and yolk from front of diff
Hope that helps.
Hope that helps.
okayyyy
Hope that helps.
Hope that helps.
I didn't know you can use the w58! sweet! And the tranny mount thing, thank goodness. thanks for you input.
Dew511.... I just tried the r154 trans mount last night and it did not line up. the width of the mount is too short. It also has an angle on one side of the mount that wouldnt sit flush.
I used the mkiii clutch pedal/master setup. mounted it to the firewall and old footbrake mount
