whats the width of your tires on 20"s?
just blew a tire in the rear. They rubbed out on the inner side of the wheel well but i couldnt find a spot they kept hitting. anyone else have this problem? and anyone else have crucial rubbing on the high way going onto and off of bridges? just wondering.
what was the size of your tires?
if you matched them up to match the same overall size of the stock tires, then you shouldn't had an issue unless your suspension was to soft/loose, or they were to wide.
what are the specs of the rims and previous tires you had?
and the offset? what size are the tires?
if it was all matched up, and the offset is not to severe, you shouldn't have problems.
my 18's with a 265 wide tire doesn't rip my fenders apart,
find out the offset. but if it's a 8.5 wide tire you should have around a 245/30R20 or 235/35R20
Well he was smoking crack i found them online
-BIGG game wheels 20x8.5 has a offset of 15
http://www.bigwheels.net/?location=w...l=Game%20Black
I'm running 20x8 up front and 20x10 rear and my tires size 245/35/20 up front 275/30/20. I only rub wen I fill up my car with people oh plus im on tanabe drop springs with 1 coil cut all round.
