94 GS 300 wont crank
So i recently bought a first gen GS 300, my battery was weak so i took it out and charged it, when i hooked it back up the alarm goes off...so i turn the ignition to the acc position and the alarm shuts off..go to crank it over and nothing. the car ran fine prior to the battery, just hunting down any good advice or direction on how to fix this
alarm shut off after i put the key in the ignition and tried to start it.wouldnt the key deactivate the alarm? as far as the interior lights they stay brightly lit when i try to crank it. but i hear a single click from the trunk when i try to crank it
That could mean various different things. Does it have an aftermarket alarm installed? Like Kaiser was saying earlier, it could be that. Have you checked your starter? If it didn't even turn that could be another reason. If it's not turning and your lights stay on after you turn the key, then I would check those 2 things first. From there try the alternator, fuel pump, then the spark plugs. Good luck
