mines ecu
mines ecu
hey,
just wondering if anyone on here with a aristo or 2jzgte swap is running the mines ecu? what features does it have? I am running a aristo motor with epik's old twin k26 set up and I want to get rid of the speed governor. would the mines ecu work with aftermarket twins? or would the easier and cheaper route be just picking up an hks sld type 2?
Just get the speed defenser or whatever it's called. It's basically a voltage clamp that will trick the ECU into thinking you have not exceeded top speed.
A Mine's ECU is custom flashed so it could be any combination of modifications.
Well for me.I had the mines ecu,
It had boost cut removed speed cut rmoved and rev limiter was at 7500...worked well with my single set up... Then I was force to sell it as I needed money to by books for school..
Mines =500 dollars
Hks speed cut(the right one for our car)=200
Mines =500 dollars
