Will g35 rims fit
02-22-11, 11:49 AM
Will g35 rims fit
Im about to buy some g35 rims I found for cheap but will they fit is my question the front is 17x8 back is 17x9 tire size 225 50 r17
02-22-11, 12:22 PM
Maybe, maybe not. Offset??
02-22-11, 01:03 PM
I've seen several JZS147's with G wheels, and like ace says, depends on the offset. Bolt pattern is fine, which ones did you have in mind?
02-22-11, 01:21 PM
02-22-11, 01:29 PM
You should be fine. The worst that can happen would be needing a 5 mm spacer in the rear.
I just picked up G35 rims as well but the 18×8s.
atif7x7
GX - 1st Gen (2003-2009)
04-24-13 06:13 AM
1JZ300
Wheels, Tires & Brakes Forum
07-23-06 06:20 PM
turboLS
05-10-02 08:46 PM
17x9 ,
18 ,
1994 ,
22550r17 ,
es300 ,
fit ,
g35 ,
gs ,
gs350 ,
is300 ,
lexus ,
ls460 ,
rims ,
tires ,
wheels
