change starter w/o the coolant issue - 1.54hrs ttl
The story goes that the front (at times) and the rear (mostly) cross-flow head coolant manifolds are to be removed as part of the starter R/R project.
Not so - follow the guides, w/o the mainfolds ( no leaky) involved. Get a friend or your small handed wife to work the flex-end racket that you will use to remove the starter bolts from the firewall side... You'll get it..
We did.
Big man hands will need to be taped up first - cutting ... n all.
In the end of this simple bypass - probably expressed by hundreds before me, but my search failed,... well it worked just perfectly.
Redundant post I am sure, so sorry to pee in a full pot.
M
We did.
M
S K I N N Y arm and tiny hand.
