Should I do spacers?
don't let others tell you what to do with your car, that's the dumbest thing ever.
if you think it should be pushed out more, then buy some bolt on spacers, or longer wheel studs and some slip on spacers and push them out. every mm of spacer you add, it pushes it out 1mm more towards the outside of the bodywork/wheel well.
if you think it needs to be pushed out 10mm more to get the look YOU are after, then get a 10mm spacer, simple as that, it's your car. **** what others think of it
but in my opinion, if you wanted a wider stance, you should have just got a wider rim off the bat, and not have to mess around with spacers
