Squeling and low idle RPM...Does anyone have any advice on how to fix this??!!
save yourself the 65$ and follow this. Its exactly hat they are going to do with a simple diagnostic.
http://www.troublecodes.net/Lexus/
You will be looking in the engine bay for the square plug in the first picture. It will say "diagnostic" on the top and also have a stick of each pin's identification under the cap.
As for the 2 spark lugs in the rear, I personally would not worry about them unless I am misfiring, or having issues because of them.
kene thnx for the tip but i didnt want to risk anything so i took it to the local import mechanic and they discovered alot of other problems. my GS had 3 oil leaks spots, it needed a new air hose, and distributer cap and plugs because oil had ruined them. Should all be done by Monday, and should be running good as new.
sounds good AJ STYLEZ
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Thanks KENE n DWOU15. DWOU15 let me know how the is ride is feeling and if the oil leaks have stop cpmpletely. I now have a oil leak somewhere and it's leaving spills on my driveway. I have light colored pavers installed in my driveway. So the wife is pissed!!! Any secret tips on how to take out oil stains off my pavers???
there is a product at autozone called purple power that works wonders, but if you are afraid of the chemicals on the driveway(some people are), there is also another product called Bio-Rem 2000.
I have personally used it at work and it was great in cleaning the grime off of the concrete pavements, and worked wonders on my office desk. Its 100% natural(uses microbes that feast off of carbon/petroleum products. They supposedly are using it for last years oil spill in the gulf, and I can vouch the stuff does work.
Is your driveway a very "pourous" material? If so it may be a bit harder to clean, but if it is slick & smooth this may be the Bio-friendly thing for you.
the distribution company is "dtdistribution"
Hey Kene,AJSTYLZ and DWOU15. I was so focused reading on this thread, and wow nice communication.
I had the problem with my GS300's rpm rev due to the problem from the TPS, and the way i fixed it was vary odd, I moved it tilt just a little and some how that cause to change the rpm rev from 2000rpm into now 850rpm. another If this doesn't make sense, I moved around a little bit tilt of the ignition distributors and create a change the rpm to change.
So I adjusted that way and left them like that into the RPM proper standing.
Is that Bad lol?
Btw massive respect to Kene information, I agreed with the symptoms
Is that Bad lol?
Dennzo
12-06-11 04:49 PM
