The Official GS300 to Lexus Part Interchange thread
Old 09-26-20, 09:05 PM
  #136
Gensc300
Gensc300's Avatar
Default 1uzfe alternator to 2jzge
Ls400 alternator bolts up to 2jzge no problems. Aslong as round plug is the same.
Ls400 alternator to 2jzge. 2jzge alternator on the left and 1uzfe ls400 alternator on the right. Shave 5mm on top mount bolts right up.
Old 01-01-21, 04:44 AM
  #137
Lysas
Lysas's Avatar
Default Diff fit
Hi everyone.
Need help on GS gen2 diff fitment, i want to change final gear ratio on diff. From what cars rear diffs fit to gs gen2? Or ar least only internals, to change ratio.
Thanks for answers!
Old 01-02-21, 10:14 PM
  #138
joewitafro
joewitafro's Avatar
Wrong section (this is gs gen 1).. but its a 200mm differential, and 1991-2000 jzs147/jzs161/jzz30/automatic JZA80 will fit internally.
Old 04-26-21, 08:35 AM
  #139
Bigjon83
Bigjon83's Avatar
Default Need to know
I have a 2000 gs 300 will the spindle and knuckle from a 2002 camera work on ot
Old 04-27-21, 08:26 PM
  #140
Arsenii
Arsenii's Avatar
Hello,
Toyota Camry has a completely different suspension and drivetrain layouts, so neither the hub nor a knuckle off of it will work for your car. The only other car you can take those parts off of is Lexus SC430.
Hope this helps and best of luck!
Old 05-17-21, 11:21 AM
  #141
Robert200
Robert200's Avatar
Default Sc300 spoiler/wing on a GS400
Does anyone know if the SC and GS wing/spoiler share mounting points I found a nice aftermarket wing for the SC and couldn’t find the answer anywhere
Old 05-17-21, 10:14 PM
  #142
Arsenii
Arsenii's Avatar
Hello,
Unfortunately, the curve of the trunk of SC300/400 is completely different, so it appears that you will have quite a time trying to bend it into place. There are plenty of aftermarket wings designed specifically for GS, maybe you can find something similar specifically for your car..?
Old 05-18-21, 06:26 AM
  #143
Robert200
Robert200's Avatar
Originally Posted by Arsenii
Hello,
what about the LS300/400? Looking for something like this but can’t find it
Old 05-18-21, 06:50 PM
  #144
Arsenii
Arsenii's Avatar
Sorry, but I am not sure something like this would really fit in the aesthetics of a 1st-gen GS300, let alone being an option for one. How about something more subtle, here you can find some of the options specifically for your car..
Old 08-28-21, 10:25 AM
  #145
kyfami
kyfami's Avatar
Probably has been gone through, however we searched for a while..
What exhaust parts interchange? The secondary cat on our '94 is clogged, obviously 2GS won't fit - however is there anything in the SC/A80 range that would mount up, cat or test pipes?
Old 10-18-22, 04:54 AM
  #146
HaydenHcc
4th Gear
HaydenHcc's Avatar
Hey guys I can confirm the 2gs front sway bar doesn't fit. Sc300 rear does.
One guy on another threat said the 2gs front does however so I went ahead and baught one to learn it doesn't! He also mentioned there's apparently heaps of aftermarket options for the 147 anyone able to point me in the right direction or am I just 10years or so to late?
Can anyone else confirm if it's possible to make the 2gs front bar fit somehow? (2gs bar is different shape and shorter so maby with different links?
or is there a sway bar from something else that fits?
Chestie (12-03-22)
Old 02-22-23, 07:44 AM
  #147
qainat
8th Gear
qainat's Avatar
Default Help - rear shock absorbers discontinued
Hi All,
I have just learned from LexusPartsDirect that the 1st Gen rear shock absorbers have been discontinued.
Does anyone know which other Lexus / Toyota car shocks will fit a 1st Gen GS300?
Old 07-05-23, 03:37 AM
  #148
Chestie
8th Gear
Chestie's Avatar
Originally Posted by qainat
Hi All,
AFAIK the front of the mk1 is the same as a mk2, while the rear is the same as a mk4 supra one.
Cheers.
Egs300 (03-23-24)
Old 01-08-24, 01:31 AM
  #149
hoanghai
1st Gear
hoanghai's Avatar
Does the Supra coil fit the sc300?
kene
03-28-16 06:35 PM
Nauta
Performance & Maintenance
12-12-14 06:01 PM
skarocker
Suspension and Brakes
10-11-12 03:37 PM
MKIVS374
SC- 1st Gen (1992-2000)
15
05-08-11 04:00 PM
mikepae
Wheels, Tires & Brakes Forum
10-10-06 09:05 AM
Quick Reply: The Official GS300 to Lexus Part Interchange thread
