Fixing Aristo foglight
I recently hit a curb in my car pretty hard and it broke the yellow glass piece that goes over the bulb and knocked loose the cage inside the foglight.
Now what I wondering is can I get a replacement for that yellow glass cover that goes over the actual foglight bulb. And, how can I remove the foglight from the backing so that I can make these repairs, specifically the cage which can only be reattached from inside the light.
if you take the foglight assembly out, unscrew the cap to access the bulb, you should see a couple screws that allow you to take out that whole cage, that has the glass "condom" in it, then it's a case of a simple, bending the tabs to remove that glass man, or install it again
TAMR_GUS98
09-05-18 04:48 PM
ChrisTapia
10-20-06 03:38 PM
