Fog light upgrade
Old 09-15-02, 04:36 AM
Jmai22
Jmai22's Avatar
Default Fog light upgrade
Anyone here change there foglights to something aftermarket yet?? i mean the whole housing not just the bulb. i'm looking for a good fog light housing application preferbly 9006 so i can put my current HID's in there since i will be having a extra set of 9006 HID's after i do my retro.
My current fog light setup is bright but not enough for me. here is my current setup
Stock housing
Glare guard removed
Piaa super Plasma's H3
i was thinking of eigther drilling the whole bigger and splicing the wires and trying to fit my 9006 HIDs in the stock housing but i figured the stock housing would not direct the light where i want it to go.
Does anyone know of a 9006 Foglight with projectors. my main concern on my car is my lights as many of you know. LOL. i drive in very dark places often and like to see where i'm going
Old 09-16-02, 06:45 PM
C to the O
C to the O's Avatar
what's the glare guard?
Old 09-16-02, 10:07 PM
CyberSC4
CyberSC4's Avatar
if you look into the foglight from the back (through bulb socket hole)...you'll see that there is a metal "blocker" that keeps the light from shining directly out of the foglight. Instead, the only light sent out is what is reflected from the back of the housing.
I just bent the glare shield out of the way and viola! brighter foglights. Looking at the fogs, you can see the bulb through the glass rather than seeing the shield.
I have not had any problems with glare on other drivers since doing this mod.
Old 09-16-02, 11:53 PM
Jmai22
Jmai22's Avatar
yes exactly what he said. but in simpler term its a piece of metal that is blocking the actual bulb.
Old 09-17-02, 01:47 AM
geees300
geees300's Avatar
Jmai,
If you opt for the 9006 and end up drilling the stock housing you should still be able to aim the lighting with the factory adjustment but up or down only. What I ended up doing with mine was lay over an amber lense protector instead of the ordinary clear film. Check out the attached image.
geees
Old 09-17-02, 02:02 AM
Jmai22
Jmai22's Avatar
what kind of front kit is that? is that the factory fog?? well i was planning to put my current 9006 HID in there and i love the color of my current HID 5300k check out my other thread. so i don't really want to put a yellow film over it.
Old 09-17-02, 02:50 AM
geees300
geees300's Avatar
It's the titan agressor kit from aerogear and yes those are the factory foglights with catz the same with the headlights.
Old 09-17-02, 03:01 AM
Jmai22
Jmai22's Avatar
i heard the stock fog light won't fit onto that kit that is the reason why i didn't get it. i had and i still believe i do have this chance to pick up a free front bumper. but i didn't want it because the stock fogs didn't fit. and also would look funny with my stock rims hieight and only mod was a front kit. LOL
Old 09-17-02, 07:48 AM
2Lexos
Chicago Lexus Club Moderator
2Lexos's Avatar
the fogs on that car look like the JDM fogs for the aristo....which is what i have on my car.......but i might be wrong....
EDIT: i just realized i posted a pic which i sent to veilside showing(or not showing) the piece i'm missing from the JDM fogs.....
Old 09-18-02, 10:41 AM
Pianoman72
Pianoman72's Avatar
Oh, so the JDM fogs are curved and the stock ones are the boring square ones.
I like geees300's setup. Very tite. Only prob is, if I modded the fogs then I would then have to figure out how to get FOGS+parking lights only.
hey mischief, does it have the wiring diagram for the headlights in your CD-book?
Old 06-18-10, 08:05 AM
worker
worker's Avatar
has any1 install HID without removing the glare guard in the fog light?
I don't want to do anything but install the 35Watt HID and that's it. But I afraid it might be too hot and melt the fog housing.
Old 06-18-10, 11:12 AM
1stGS30
1stGS30's Avatar
Old 06-18-10, 02:43 PM
veritek
veritek's Avatar
^Wow, that's hot. I've always loved the double fogs, and have never seen it on a 1GS before.
Old 06-18-10, 02:45 PM
veritek
veritek's Avatar
That's ironic, cuz I'm missing that same piece, but on the driver's side. Have you tried to source a replacment yet? Maybe we can go in together and split up a set if you or I can find one?
Old 06-18-10, 05:29 PM
AJ.STYLEZ
AJ.STYLEZ's Avatar
Geees.. what foglights you have on your front bumper?? are they the factory fogs??
Quick Reply: Fog light upgrade
