1993 Lexus GS300 problem....
Well my wiper washer does not work. When you press button for washer it turn on wipers but no water gets squirted out (yes washer bottle is full). There is no separate fuse for washer I believe it is connected to wipers and they work. Anyone had his washer motor go bad? Could it be bad connection thank you.
Because when I got mine it would still make the sound but no fluid, turned out the small hoses to.the squirters weren't even connected, but that's strange I never heard anything like that before
well if it's not making a sound, then chances are the pump has bite the dust and should be replaced. look under the dash at the fuse panel, and under the hood in the fuse box, and see if there is a fuse for it, simple as that
