Custom Subwoofer Enclosure
Does anyone know if there is a custom subwoofer enclosure for our GS. I have seen them for the 2nd gen GS but not the first. Or will the 2nd gen enclosure work. I have read the thread on removing the factory sub and doing a free air setup, but there are not a lot of options. I really do not want to lose a lot of trunk space and want a custom look.
im in the middle of building a box to mount to the bottom of the rear deck and will be running a kicker cvr 12. ill take pics of the box once its done, and then after its bolted into place under the back dash. it fits on top of the gas tank. not alot of room there, but will leave all of my trunk space. and the 12in sub will bolt in from the top.
we got the basic box done a couple weekends ago, but havent had time since to mess with it. im hoping we can finish this weekend. we are trimming some more from the back so the rear wall of carpet that blocks the gas tank will fit better etc... most of that day was spent running the wire for the amp. ran a 4awg from the battery through the fender along the main harness under the fender, then through the firewall in the kick panel(major pita to get to the wire to pull it through btw) then along the driver side under the carpet and through the upper gromet behind the driver seat. the rca wires went on the passenger side. you wont see any wires in the trunk at all, and the only give away under the hood is the batter having an extra 4awg cable connected. it runs between the battery and fuse box to the hole in the fender.
hey guys, here are some pics that i found travelling the net. it looks like they have made the enclosures using the side carpet hardened with fiberglass and an MDF face plate. i think its a very good idea still leaves you with nice boot space and it looks clean.
![](http://img826.imageshack.us/img826/7572/48043158422784245711385.jpg)
![](http://img864.imageshack.us/img864/6756/58595158422488238311385.jpg)
![](http://img803.imageshack.us/img803/6914/59084158423000251111385.jpg)
cheers
dan
cheers
dan
no, mdf. i actually finished the box. forgot to take a pic before bolting it in place. i still need to trim the rear carpet wall piece to fit around the enclosure and make an amp rack to fit up next to the gas tank that will be behind the carpet wall as well etc... i snapped a pic of the sub from the top before the rear cover was on and of the box mounted, just havent got them from the camera to the pc. was tired as hell. took forever to get it to fit perfect and seal completely to the bottom of the rear deck.
cheers
dan
cheers
dan
my brother actually tried to talk me into doing a similar setup with two 12's. i decided not to. the couple pics i took didnt come out very good. it was dark. ill take more this weekend as i finish it up and post later.
Jump2man3
02-11-15 09:17 AM
ProfesrLEX
05-26-12 12:15 PM
ZippyGuy
11-16-10 06:04 PM
Purplexed
07-23-01 10:00 PM
