Ghost Rider
#31
Ghost Rider
Does anyone know how to rest the ABS SPEED SENORS once they are disconnected. What voltage does these sensors have to be? I have a voltage meter. so can someone help me...
#35
Ghost Rider
Where can i find another ignitor control module for a reasonable price instead of the OEM thats price at 356.00. is there anything else i can use to give me some spark to my ignition coil and distributor? Can some please help me. What about MSD SPLIT FIIRE. Is this Equipment good for my car what do you guys and gal think about that.
#36
Dude stop with the ghost rider crap. You should start ONE thread titled something like HELP. Don't make a new thread 50 times a day. Now on to your question. Unless you're building up your motor and have a need for more spark stay oem. Don't mess with your ignition or fuel. Just get an oe replacement igniter and you'll be fine.
#39
Toucan reset the abs kam by disconnecting the battery for a couple minutes or you can reset stored codes by using an abs capable scanner. As for using the splitfire ignition system I would advise against it for what you're doing. A junk yard would nethecheapest place to get an igniter. You'd probably pay more for an aftermarket ignition system. Have you shopped around? Call all the parts stores around you. Look online. Check eBay. Look everywhere. You'll eventually find one at a cheaper price. Just keep in mind. You get what you pay for and if you buy it online you probably won't getthebest customer service
