Ghost Rider
You got pipes now u need to set your ignition timing? Must be because the inverberator valve in the unslung choke rod orifice retards the timing to increase the headlight fluid pressure ..... Wait...WTF?!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Does anybody know what the torque wrench specs. for the 95 Lexus GS 300 exhaust manifold. I just put new gasket on and it still leak. I don't want to be too tight or too loose.... Can someone please help!!!!!!!!!!!!
There's marks on the timing gears, they go pointing straight up, lining up with the 2 marks on the timing case, then you take off your distributor and line that up too
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
how do you repair a abs code 31 right wheel speed sensor signal malfunction. can anyone help me. also i have a code 24 abs open or short circuit in 3 position solenoid circuit for left rear wheel how can i solved these problems. someone please help meeeeeeeeee
