fuel pump upgrade
fuel pump upgrade
ls400 obviously has a bigger engine, stronger and needing more fuel, so is the fuel pump stronger/more powerful than the gs300's? and would it bolt on like most lexus/toyota parts? minimal work is ok as far as fabrication....
Just from the short google search I did, it looks like they are both 255lph, so it looks like they are the same It was a good idea though...as far as I know, the only upgrade would be a Supra fuel pump...I guess the LS pump is a 255lph pump too, but DeatschWerks makes a 300+lph pump that fits the LS430...which is only $170
Check this out..this could be worth looking at - Aeromotive 340 Stealth Fuel Pump ". Comparing to other popular aftermarket fuel pumps, at 40 psi the 340 boasts more than 340 lph. That’s over 30% more flow."
http://www.tunersports.com/aeromotiv...140_p4664.html
