1jz swap in first gen gs
Jus wondering if anyone put a 1jz non vvti motor in the first gen & what needs to be done to get it runing.such as what mounts,harness and stuff
I've considered it as I have the 1JZ just sitting in my Supra right now chilling. It's down because of transmission issues so it's got me itching to do it. The hardest part would be the dash plugs but if you were able to use an Aristo harness and ECU that would take care of that. Just need to wire the injectors to work correctly.
Will start one up this evening, or this weekend, something like that. Im trying to have everything together by july 8th to take it up to the P.P.I.H.C. so iv been laid out in the garage pretty much every day doing something, and just spaced posting my work soo far on here. Still need to have my drive shaft made, clutch- pedal, slave, master, and line, installed, need is300 igniter,a 1UZ MAF, fuel pump, and the patience to sit down and extend 153 wires 30 inches
"Pikes Peak International Hillclimb" all the guys that go spectate will usually bring out their nice cars and projects to take up the mountain, and twould be nice to show up with the 1J. And will do I still need to do a intro thread anyway.
Here you go I did this a while back so if you have any questions I'll try and help.
https://www.clublexus.com/forums/gs-...most-done.html
