Stripped head stud! HELP!
Old 04-29-12 | 02:12 PM
m1k3yg's Avatar
m1k3yg
Default Stripped head stud! HELP!
I am in the process of changing my head gasket, I managed to take pretty much everything off, except for one of the 12pt head studs that decided to strip while the rest came out fine, I seriously have no clue on how to sove this show stopper I was hoping you guys could shoot me some help
Old 04-29-12 | 02:16 PM
m1k3yg's Avatar
m1k3yg
Old 04-29-12 | 02:18 PM
Nova's Avatar
Nova
get a larger size or use a larger hex, thats what i did to my 2j when one got stuck used a larger hex hammered it in and came right out
Old 04-29-12 | 08:01 PM
m1k3yg's Avatar
m1k3yg
I have a hex that is the same size, but it gets stuck because the opening isn't big enough (not the head of the bolt, the area around it) so i'm going to see how I can get in there, I was thinking a drill bit with a reverse thread that they sell but I don't know since it's torqued real good in there
Old 04-29-12 | 08:29 PM
Nova's Avatar
Nova
i believe the head bolts are hardened so the reverse drill wont break it loose the only thing it will do is get down far enough to break the head off so you can remove the head.
Old 04-30-12 | 05:48 PM
RAMPAGEsd's Avatar
RAMPAGEsd
you can try this http://www.sears.com/shc/s/p_10153_1...ku=00952166000
Old 04-30-12 | 07:00 PM
Nova's Avatar
Nova
Originally Posted by RAMPAGEsd
that will not fit in the head.
OP any update?
Old 04-30-12 | 09:08 PM
m1k3yg's Avatar
m1k3yg
OP any update?
Honestly I haven't tried, weather was pretty crappy today, I was going to try to get an allen key that fits in there, put it through the closed end of a wrench of the respective size, hammer the.allen key in the hole and hopefully getting it out, but i've read that there is kits for cases like these, I was gonna call a shop but idk what they would say
Old 05-03-12 | 02:57 PM
m1k3yg's Avatar
m1k3yg
Ok guys I got the head off! ***** nasty! pics up in like an hour, im trying to figure out how to replace valve seals
jwin
Performance & Maintenance
11-30-12 05:00 AM
copermn
SC- 1st Gen (1992-2000)
28
07-26-11 11:29 PM
DRFT103
04-28-10 10:32 AM
1siksc
04-29-08 04:06 PM
tuninghaus
12-19-06 10:57 AM
Quick Reply: Stripped head stud! HELP!
