Project one pics
this is one side. i'm still not done yet. its taking longer than expected. i'm planning to reopen it up and finish sanding down the bottom area in the corner and in front of the high beam. also paint the inside dark grey or black still undecided
don't see what?? your not suppose to. the first of the 2 pics is the one where i have sanded down the lines. the 2nd one is how stock is. i'm still not done with the first one.
IT really does increase output and has a cleaner cutoff line. those lines that used to be in there caused stray light beams to go in different direction. now that its clear the light comes out and shines on the street exactly how it comes out of the projector.
good eye. its for my external speakers so when i roll through the ghetto i can bump my system and be cool as shiz. also i can get on the loudspeaker and tell peepz to get out of my way. j/k
ok foreal now. When i did my retro the guy that did it decided to use speaker wires because they are more flexible to run my power wire for my HID ballast for my low beams.
